You would have to put a tee fitting there with an oil pressure switch that is normally open and closes with pressure. I have that on an H & it works fine. No bulb to break or burn out. aLSO IF THE AMP GAUGE SHOWS IT'S CHARGING, YOU KNOW IT HAS OIL PRESSURE TOO. Sorry, I hit the caps button.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
