Re: 300U pto revisted
Posted by CNKS on June 02, 2013 at 17:04:12 from (216.144.104.128):
In Reply to: 300U pto revisted posted by Dave H (MI) on June 02, 2013 at 14:15:56:
The bands are independent of each other, it doesn't make any difference which one is tight or loose. You adjust them as Jim says, with the lever in the middle then try to turn one with the lever locked down and the other with the lever locked up. If not successful after you use an implement and can't get it to work you need to replace the bands.
