Re: Engine won't STOP running
Posted by Owen Aaland on June 02, 2013 at 17:39:41 from (216.47.35.254):
In Reply to: Engine won't STOP running posted by equeen on June 01, 2013 at 19:54:15:
Maybe a description of what happens in the alternator will help clarify why a resistor or diode is needed in the #1 terminal. Here is a link to the service manual for that series alternators.
http://www.autoelectricservice.net/images/Delco_10SI_Technical.pdf
If you follow the wiring diagram for the regulator you will see that the #1 terminal is connected directly to one of the brushes to provide electrical power to the rotor to create the magnetic field necessary for the alternator to operate. The regulator controls the connection of the other brush to ground to control the voltage. You can also see that the diode trio inside the alternator provides power internally once the alternator starts to charge.
This internal connection is also why there should be some sort of current limitation on the circuit for the #1 terminal. Without some sort of current limitation the entire output of the alternator will be available at the terminal if the connection between the output stud and the battery should become an open circuit.
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
