Re: 300U pto revisted
Posted by pete 23 on June 02, 2013 at 17:58:22 from (74.44.101.209):
In Reply to: 300U pto revisted posted by Dave H (MI) on June 02, 2013 at 14:15:56:
Well, first off, the number of threads means nothing as the bands wear at a different rate. You adjust both until just snugged down, no lever movement with centered. Forget about the punch marks if they are not visible. Then back each one off same amount like try one turn. With lever still centered you should be able to turn the shaft with a short 5 inch punch. Channel lock works fine. If you can not readily turn shaft, back both screws out equal amount until you can turn shaft. Then lock it down. You should not be able to turn shaft in either position, engaged or disengaged. Also, no significant drag on engine when running with lever disengaged for engaged. Most likely will make more noise in the disengaged position as planatery gears are turning faster then.
