The gen light, or resistor, will allow only about 1/4 amp to backfeed from the alternator to the ignition coil, not nearly enough to power the coil and make a spark, so the engine shuts down normally. A diode totally blocks any backfeed from alternator to coil, but will allow about 2-3 amps to flow from the ignition switch to the alternator, nearly doubling the load on the ignition switch and wiring. This can cause voltage drop and weaker spark from the coil.
Thats why I perfer to use the gen light. 1 it only adds 1/4 amp load to the ignition circuit, so the coil sees less voltage drop and makes stronger spark, 2 it serves as a charge / no charge indicator, 3 It reminds you that you forgot to turn off the ignition, so you do not run down the battery.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
