Re: Creeper gear
Posted by mkirsch on June 03, 2013 at 05:10:00 from (64.80.110.74):
In Reply to: Creeper gear posted by joshua rod on June 03, 2013 at 05:01:56:
It's not a creeper gear as in an actual gear.
It's a HYDRA-creeper. Basically, it is a hydraulic motor tnat turns the PTO shaft.
The trick is, you block the clutch pedal down and engage the PTO, then use the hydraulic motor to move the tractor at a very slow speed.
