Re: More hydraulic questions
Posted by Les Repair on November 20, 2000 at 17:16:30 from (206.28.174.55):
In Reply to: More hydraulic questions posted by Brian on November 20, 2000 at 11:56:50:
I'm not sure what the high limit of pressure would be, but the timing gears which drive the pump are one of the limiting factors. They will break.
Post A Followup
: Re: Re: More hydraulic questions
