Re: 1066
Posted by The tractor vet on June 03, 2013 at 06:41:36 from (76.212.226.211):
In Reply to: 1066 posted by trailrider82 on June 02, 2013 at 19:29:14:
While turning and usen the brake tells me of low MCV pump output .or like others have said low oil level . If this happened while going down hill then i will go along with a low oil level . if you were on flat ground then pump output , a sticking flow divider , internal leakage in the T/A , dirty hyd filter . Check the easy stuff first change the filter and check oil level. And if needed then add a couple gallon more oil. Then if all this does not FIX the problem then get your PIGGY BANK out .
