Re: IH 300u - Runs but Misses on a Cyl. What is it?
Posted by old on June 03, 2013 at 07:49:26 from (209.86.226.56):
In Reply to: IH 300u - Runs but Misses on a Cyl. What is it? posted by RTR on June 03, 2013 at 07:20:07:
Trouble shooting 101 says check the spark at ALL 4 plug wires and make sure you have a good blue/white spark that jumps a 1/4 inch gap or more. Next take a propane torch or a can of carb cleaner and spray the intake manifold area around where it hook to the engine. If the RPM changes you have a vacuum leak and the gasket or manifold may need to be replaced. Also see by changing the plugs around if the miss goes with the plug
