Re: Farmall H mainshaft seal removal
Posted by Bob M on June 03, 2013 at 08:03:08 from (65.110.157.186):
In Reply to: Farmall H mainshaft seal removal posted by charlespretzer on June 03, 2013 at 07:44:22:
Yes to both your questions.
To unscrew the hyd pump drive coupler from the countershaft, block the rear wheels and put the transmission in 1st. Now grab the coupler with a big pipe wrench, or stick a suitable piece of square stock in the coupler slot. A good yank on the pipe wrench, or a lick with a hammer on the square stock will get the coupler started. Once broken free it will spin off easily by hand (threads are normal right hand...).
Also - I recommend dropping the hydraulic pump first to give room to work.
Good luck - replacing those seals is not a difficult job!
