Re: Farmall H mainshaft seal removal
Posted by RustyFarmall on June 03, 2013 at 08:05:07 from (216.248.71.226):
In Reply to: Farmall H mainshaft seal removal posted by charlespretzer on June 03, 2013 at 07:44:22:
The main driveshaft also has to be removed, which means you will need to collapse the pressure plate slightly. The hardest part will most likely be getting those tapered coupler bolts out. Persistance pays, but you will probably learn a few new words along the way.
