you answer ur own question, compression is great so no need to pull head. should post compression results. can be as simple as a dead plug so switch it with another one and see if problem follows plug. with wire core wires its unlikely to be a wire as i have 60 -70 year old wires working. only if the insulation is off it may be grounding out. being slightly out of time will not cause a miss.have a look in the cap terminals for green corrosion make sure the main load screw is turned out at least 3 turns up to 5 for heavy pulling. is the carburator clean? the most likely think is either a plug or a corroded wire. do a check with all plugs out. ground each plug to the block and have someone crank it over. should see and hear the spark snap on each plug.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
