Re: Engine Oil Blow-by
Posted by dej(Jed) on June 03, 2013 at 09:07:01 from (141.189.251.1):
In Reply to: Engine Oil Blow-by posted by equeen on June 02, 2013 at 10:55:40:
When my O-rings failed in my hydraulic pump, the hydraulic oil went from there to the crankcase. This caused the engine to pressure up and push oil out. Are you losing hydraulic and gaining engine oil by any chance?
