Re: Setting valve tappet gap on Super A
Posted by teddy52food on June 03, 2013 at 19:49:50 from (184.94.175.179):
In Reply to: Setting valve tappet gap on Super A posted by equeen on June 03, 2013 at 11:53:18:
If you do it Jim's way , you can be off a few degrees of rotation & still be ok. If you do it CNKS 's way , you will need to be right at TDC which is hard to find the marks on most flywheels. I watch the running mates & when # 4 is between ex & in , I set #1. then do the rest in order 1342.
