Re: Another Magneto Question
Posted by gene bender on June 04, 2013 at 01:34:25 from (67.55.226.83):
In Reply to: Re: Another Magneto Question posted by Fawteen on June 03, 2013 at 18:25:54:
The H-4 mags I have on the A and Bs I fasten them in the vice turn them over with batt drill then with each wire hooked to a sparkplug on a metal bench I can check the fire at impulse and different speed and I have never worried about how strong the magnet is. I have taken them apart and cleaned the armature and magnet to be sure its clean and not covered with rust. After test I know it will work on the tractor and I will use a heat gun on the coil to see if it works when heat from engine gets running.
