Re: Another Magneto Question
Posted by Fawteen on June 04, 2013 at 08:28:00 from (72.65.111.11):
In Reply to: Another Magneto Question posted by Fawteen on June 03, 2013 at 17:49:25:
Took the mag back off.
Opened up the point gap a touch.
Cleaned the distributor disk and carbon contacts.
Checked the continuity between the secondary contact and the coil, cleaned and snugged up the coil contact a bit.
Because I've had the carb off and the fuel pump apart, I rigged up a gravity feed tank to be sure I was getting fuel.
Cranked up and ran, a little ragged but it ran. After it had been running a bit, I cracked the petcock on the fuel line to be sure the pump had primed.
I'll finish putting it back together and tweek the carb a little and I think I'm there.
Thanks for all the help!
