Super A Jack Pads
Posted by Charles Green on June 04, 2013 at 15:32:02 from (75.174.102.77):
There is what appears to be a jack-pad on the bottom of the transmision bell-housing. Can the front end of the tractor be jacked up and supported on the bell-housing while the front axel and steering gear housing are removed?
