Re: 100 hydraulic
Posted by gene bender on June 04, 2013 at 15:56:40 from (67.55.226.83):
In Reply to: 100 hydraulic posted by ken house on June 04, 2013 at 15:31:35:
Should have serviced the hy pump first as the seal will leak fluid into the crankcase therefore not having good pressure.
