1594 front axle
Posted by Doug Wis on June 04, 2013 at 19:26:43 from (174.124.6.224):
need to widen the tread on the front of 1594 so as to not run on the hay swath. Bolts came out ok, but as I expected the axel won't slide out.Anybody got any tricks up their sleeve to get it to move. The axle tube is triangular in shape rather than round like most so you can't break it free by turning it . Too big to heat. It's currently set as narrow as it can go. Thanks
