Re: IH 2504 quadrant shafts seals leaking
Posted by ja1724 on June 05, 2013 at 09:28:39 from (96.57.208.235):
In Reply to: IH 2504 quadrant shafts seals leaking posted by Bob on May 31, 2013 at 09:59:45:
I have discovered that the quadrant support is also broken, the position control lever shaft is bent, and the draft sensitivity control shaft is bent. Anybody know where I might begin to look for these parts?
