Re: BN stuck engine/oil pump removal
Posted by Dalex on June 06, 2013 at 19:51:22 from (108.38.146.180):
In Reply to: BN stuck engine/oil pump removal posted by Royse on June 06, 2013 at 18:59:00:
I had the same problem with my Super "A" last
year. I removed the bottom cover on the oil pump
and made a plate with 4 holes to bolt onto it. I
drilled a hole in the middle of the plate big
enough to get the threads of a slide hammer
through. I put a nut inside to hold it. Then
bolted the plate on. Using longer bolts, draw up
the bolts so they go all the way though , but
allow the slide hammer to wobble a little. A few
slams and it popped right out! A little honing
with a ball/brush hone and it slid in and out
easily....
