Re: BN stuck engine/oil pump removal
Posted by teddy52food on June 06, 2013 at 20:10:21 from (184.94.175.179):
In Reply to: BN stuck engine/oil pump removal posted by Royse on June 06, 2013 at 18:59:00:
Get the oil pump out with a slide hammer set-up. Then remove the crank, keeping tract of the rod & main caps so they don't get mixed up. Then you can drive the pistons and sleeves out together. Make sure you get new o-ring seals for the sleeves & clean the block good where they go in.
