Re: BN stuck engine/oil pump removal
Posted by Hendrik on June 07, 2013 at 01:10:12 from (194.53.253.51):
In Reply to: BN stuck engine/oil pump removal posted by Royse on June 06, 2013 at 18:59:00:
All good tips and I'm sure you will get the pump out.
Since the gear on the pump shaft (driven by the camshaft) is a helical gear, either the pump or the camshaft (or both) have to be able to rotate slightly while pulling the pump out. So make sure either can rotate; otherwise you will mess up the gears :-(
HTH, Hendrik
