Re: Mag timing on F-30
Posted by robgIN on June 07, 2013 at 15:38:32 from (70.224.39.34):
In Reply to: Mag timing on F-30 posted by Mark Poss on June 07, 2013 at 13:51:36:
if you have a manual, it tells you how to time the mag in detail. Mag fully retarded points should just start to open at TDC to 8 degrees after TDC.
