Re: farmall 400 nh 477 haybine
Posted by DeltaRed on June 07, 2013 at 18:06:24 from (97.118.25.134):
In Reply to: Re: farmall 400 nh 477 haybine posted by DeltaRed on June 07, 2013 at 17:56:46:
third party image
I run a NH 499 behind a 1256.I run full/pto speed.The tractor has PLENTY of power,even at low speeds.In the HEAVY hay I was cutting today,the swather needed to run at full speed.Slow speeds cause sickle breakage,knocks more u-joints,causes other problems,and will not 'feed' or 'blow' right.
