Re: alternator conversion
Posted by farmallhal on June 08, 2013 at 05:30:28 from (76.0.47.7):
In Reply to: alternator conversion posted by jsfarmall on June 07, 2013 at 19:44:27:
Forget the Delco 10SI and use a Hitachi No. 14231 alternator which was used on late 1970"s Nissan pickup trucks. It will fit fine and still have room for adjustments and is quite simple to install on a H, Hal.
P.S. Email is open if you want some more detailed conversion instructions as I converted a 1951 H several years ago using one with no problems.
