Posted by AG in IN on June 08, 2013 at 06:44:16 from (67.237.16.174):
In Reply to: IH 806D reputation posted by Lmack on June 07, 2013 at 19:18:24:
Brent wortham said: (quoted from post at 06:27:21 06/08/13) Wasnt the shifting linkage or something bad on the 806's after awhile ?
The shifting setup wasn't the greatest, but isn't as awful as most people make it out to be. After 45-50 years many have shifting parts that are pretty well worn out. If everything is in good shape under the covers, the turnbuckle joints by the levers aren't sloppy-loose, and the 2 captive bushings the shafts go through before entering the housing are in good shape, and everything is adjusted correctly, they'll shift ok. Parts are still available from CIH and aftermarket sources.
56-series and later setup was better. Still, if the parts are worn out, they are worn out.
AG
This post was edited by AG in IN at 07:00:09 06/08/13 3 times.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
