The rainwater is trapped in the exhaust manifold and perhaps in the cylinder with its exhaust valve open.
Quickest/easiest solution: Remove all 4 spark plugs. Then crank the engine for a few seconds. This will "blow out" any water that might have accumulated in a cylinder. Finally replace the plugs and fire it up. If it runs on all 4 you are good to go.
However if you find there's a miss in one cylinder, remove the offending plug, dry it off (a soft flame from a propane torch works well) then stick it back in.
Suggest once you get the engine started, let it run a few minutes to warm it up/dry it out. And don't forget to put your soup can back on the exhaust stack when you are finished!
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
[More Ads]
