Posted by JimB2 on June 08, 2013 at 18:06:43 from (173.243.43.98):
In Reply to: 484 international posted by Lake on June 08, 2013 at 12:28:01:
Hi Lake, if I understand you correctly the HI/LO/REV lever is stuck in HI or LO, correct? Does it have the older style gear shift levers that are slide inside a slot?
This tractor has 2 transmissions, front one is speed transmission with gears 1 thru 4 and the range transmission(Hi/Lo/Rev) is in front of the diff. It would appear your range transmission is stuck in Hi or Lo. DO NOT FORCE the Hi/Lo/Rev shifter lever or you will snap off the shift lever that goes through the side of the transmission case. With engine off, chock the rear wheels, put speed transmission lever in between 2 and 3 then crawl under tractor and inspect range transmission lever mechanism for obstructions etc. You will see were mechanism connects to lever on side of transmission behind the hydraulic filter. Usually by some wiggling the mechanism and maybe a little prying you can free the shift lever.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
