Re: Remove 140 belt pully unit?
Posted by Haas on June 09, 2013 at 02:13:01 from (50.142.111.41):
In Reply to: Re: Remove 140 belt pully unit? posted by TheDurk on June 08, 2013 at 21:16:49:
No, you don't need any sleeve or bushing when you remove
the pulley gearbox and install the cover. I was talking about if
you remove the pulley from the splined shaft on the gearbox
but leave the gearbox in place. That is when you need the
retainer sleeve. There is a spacer sleeve that can be installed
in place of the drive gear that is on the tractor shaft that you
covered up with the domed cover. If anyone ever wanted your
old belt pulley gearbox they might need that gear that is on the
tractor. That is because tractors that had PTO but no pulley
came from the factory with a spacer on the shaft and no gear.
Those domed covers can be found at salvage dealers.
Surprised you were able to get a new one!
