Re: int 450 power steering
Posted by D Slater on June 09, 2013 at 09:06:07 from (184.14.160.1):
In Reply to: Re: int 450 power steering posted by Doug Brown on June 08, 2013 at 21:38:52:
Pressure opening for the line to the steering unit is the bottom port on the Regulator and safety valve block. That's the block facing the fuel tank. Return line from the steering goes to the drain opening of the reservoir with a tee and plug there so the drain can still be used without removing the power steering line.
From the description maybe someone removed the power steering unit at one time and just run a bypass hose from the pressure port to the drain port.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
