enigne diagnosis
Posted by rosedale123 on June 09, 2013 at 18:23:45 from (108.224.113.216):
It is me and my B414..I have it running - sort of. I hope you can take me the rest of the way.
here is where I am at.. the thing at high or full idle runs terrible. To the point, you would think I had 2 wires swapped. Miisses bad and backfire a some thru the tailpipe.
Here is what I know:
all 4 cylinders at 125 psi
fuel is clean
at the top of compression , #1 lines up perfectly on the timing marks and rotor positon
wires are 1-3-4-2 ( the inforamtion I have says that is correct
idle is pretty good ( I am good with it)
Idle screw out 1 1/2 turns
high speed needle is out 2 1/2 turns. I have tried alot of different setting with the high speed needle to no avail
has petronix ignition
new plugs
new fuel pimp
Zenith carb
One kind of strange thing...as it runs I pulled off one wire at a time. I really cant tell a differnce when I remove #4. I did check the spark by removing and grounding the plug and it does spark
Gosh, I cannot figure it out. Seems like it should be correct - but I am sure when I drive it the neighbors this I am shooting at them ( it is that bad).
Is it carb ( fuel) .....is it ignition???? Something else. Hope you real motorheads can provide some help..cause I have removed myself from the motorhead list as a failure.
Thanks in advance
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
