Yes in every way. It is not a compression leak, it is a cooling system into the crank case. No issue with high temp or high pressure. (I doubt that the head gasket is leaking. The seal under the sleeve ring is usually not a leak source (never seen it to be, and that is the only interface with the water, the block, and the sleeve. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
