Posted by pete 23 on June 10, 2013 at 10:25:41 from (74.32.230.205):
In Reply to: HELP! 966 posted by Allan In NE on June 10, 2013 at 05:26:54:
You look through the half inch pipe plug hole on rear side of front cover. Mark on hub to timing pointer. Will not be tdc, rather about 18 degrees btdc. Can be cyl six or one. I can readily tell if pump still works by removing three bolt plate , lines to injection nozzles at pump, all other lines still hooked up, open throttle, turn pump with ratchet and see where fuel exits head fittings. I have never seen a factory cab you cannot get at timing marks. Some not easy but can do. Have to take off that corner shield.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
