Re: COIL - CONDENSER
Posted by John T on June 10, 2013 at 13:40:44 from (72.160.139.202):
In Reply to: COIL - CONDENSER posted by peostatim on June 10, 2013 at 11:02:18:
You "properly" test a coil or condenser with an actual tester made for that purpose. However, an ohm meter test can tell you if its definitely BAD/Open but it cant necessarily tell you if its good because that often happens at high voltage and/or once up to temperature. The old analog ohm meter kick back test is pretty good for testing a capacitor although it don't give you the capacitance value like a real capacitor tester. Similar an ohm meter can show if a coil is bad/open.
John T
