Posted by old on June 10, 2013 at 14:05:23 from (209.86.226.57):
In Reply to: Re: 504 NO SPARK!!?? posted by farmallboy15 on June 10, 2013 at 09:46:25:
Spark needs to be a blue/white and jump at least a 1/4 inch gap to run well if at all. Check it at all plug wires. If you do not have that check the insulator connection going in the side of the distributor if you painted that you could have a short there.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
