Re: IH 350 Power Steering Pressure Question
Posted by pete 23 on June 10, 2013 at 18:14:45 from (74.32.230.205):
In Reply to: IH 350 Power Steering Pressure Question posted by Jim Dolan on June 08, 2013 at 12:06:15:
Power steering has it's own separate relief valve. It is a small ball valve right in the flow divider circuit. You need to take the flow divider spool out and fitting going to power steering. Then you go up through the fitting port with screw driver.
