Re: COIL - CONDENSER
Posted by Owen Aaland on June 10, 2013 at 18:34:34 from (216.47.33.251):
In Reply to: COIL - CONDENSER posted by peostatim on June 10, 2013 at 11:02:18:
I use my Sun 740 Electronic Engine Tester. It has a capacitance tester along with being able to check resistance of the coil and also power it and display the output on the scope to check for internal shorting under load.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
