Re: hich for H
Posted by Randy Hall on June 11, 2013 at 05:12:30 from (209.143.10.12):
In Reply to: hich for H posted by alderman on June 11, 2013 at 05:09:20:
the regular u shaped drawbars are interchangeable the only difference is the m uses a thicker one. the swinging drawbars are different.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
