Re: hich for H
Posted by dej(Jed) on June 11, 2013 at 05:12:12 from (141.189.251.1):
In Reply to: hich for H posted by alderman on June 11, 2013 at 05:09:20:
An H swinging drawbar will fit an M, but you will need the H pin.
The U drawbars should switch. The M swinging drawbar won't fit the H belly clevis, it is too thick.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
