Re: Re: Re: Throttle On H Slips to Idle
Posted by The Red on November 21, 2000 at 13:22:16 from (12.75.47.218):
In Reply to: Re: Re: Throttle On H Slips to Idle posted by Bob R on November 21, 2000 at 12:45:04:
Bob check your spring underneath the cap to see if it is possibly broken. If it is OK, I usually add one more washer to give the spring more tension. That square tooth cap and throttle lever is an aftermarket which I have on one of my Hs.
Post A Followup
: Re: Re: Re: Re: Throttle On H Slips to Idle
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
