IH-1000 loader issues
Posted by chad from michigan on June 11, 2013 at 17:53:05 from (96.36.15.107):
We just installed a Ih-1000 loader on my dads Super A. It works ok but the pump is getting hot hot you can"t touch it and you can smell it and it got hot enough to burn the grease and grim off.
the loader is hooked up the same as the one on my Farmall 100 but this one used to be on a farmall Cub. Could the bypass block have the wrong gasket on it do I need gaskets specific for the Farmall Super A? I am guessing dad may have used one of the farmall cub gaskets. Could this cause it to get hot?
Thanks
Chad
