Re: 200 cylinder rocker arm
Posted by clint s on June 11, 2013 at 18:00:39 from (108.183.224.168):
In Reply to: 200 cylinder rocker arm posted by steve alderman on June 10, 2013 at 18:27:14:
I made it home earlier tonight than expected.
Steve, here is my E mail Speeddial@aol.com we can up set up the particulars though E mail since PM's do not work. If I need the seat bracket(s) how much for them. I may have a bad bushing in one of mine, wont know until I get it apart. There is a bolt in mine and I cant tell it there are threads in there chewing it up or not. Could you check the rod in the bracket to see if the bushing is good???
Thanks
Clint
