Posted by Janicholson on June 11, 2013 at 20:13:00 from (74.60.94.18):
In Reply to: Re: Farmall B start posted by Pilot Mike on June 11, 2013 at 19:47:27:
Set the points after cleaning them with 400 grit and a folded dollar bill to wipe them clean. Point gap is .013". If off, the spark will be weak at low speeds. Be sure to mark the position of the rotor and reinstall it correctly to keep the rotor timed. it has gears. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
