Posted by Bob M on June 12, 2013 at 02:03:26 from (74.67.186.88):
In Reply to: lp706 turbo questions posted by chris cummins on June 11, 2013 at 21:18:52:
You can't take a stock LP carb and blow thru it either. They are designed/calibrated to operating under manifold pressures less than atmospheric - sending pressurized air thru just won't work.
You can mount a regular LP carb on the inlet side of the turbo. But this may cause problems with oil sucked into thru the compressor shaft seal at idle/light load.
Or you can get a "blow thru" LP carburetor setup designed to operate under boost pressure and mount it after the turbo.
At work we had an Onan natural gas-powered emergency generator. Prime mover was a turbocharged Ford V-8 engine. The Impco fuel system consisted of a simple throttle body mounted atop the intake manifold with the throttle shaft connected to the the engine governor. An external gas regulator metered the gas and dumped it into the turbocharger inlet thru a simple tee fitting at the compressor inlet. The regulator received flow/pressure signals from taps above and below the throttle plate.
Once adjusted system worked very well. However the exhaust manifolds would glow cherry red after the generator ran a couple minutes at full load.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
