Re: Sloppy Shifter Fix
Posted by Stumpy(NH) on June 12, 2013 at 02:31:16 from (70.109.128.44):
In Reply to: Re: Sloppy Shifter Fix posted by CTPhil on June 11, 2013 at 19:52:55:
Nope, just remove the shifter, install the sleeve, then put the pin through and tighten down. I did have to remove the three bolts that hold the steering shaft support to get room for an allen wrench on one side though.
Piece of cake
Stumpy
