Re: lp706 turbo questions
Posted by Chuckles46 on June 12, 2013 at 05:01:57 from (68.191.167.1):
In Reply to: lp706 turbo questions posted by chris cummins on June 11, 2013 at 21:18:52:
I built one quite a few years ago for a farmer friend. We blew through the lp carb. All you need to do is run a balance line from the carb/manifold to the port on the front of the regulator. Realize that lp will detonate at intake temps above 115 degrees, so water injection is a must 50/50 alcohol is even better. We used an electric fuel pump to inject the water. timing will have to be adjusted with a dyno. We ran it at approxamately 115hp on the pto. As far as i know it"s srill running today
