Posted by Jim in Ma. on June 12, 2013 at 06:27:51 from (72.70.103.19):
In Reply to: Farmall B start posted by Pilot Mike on June 11, 2013 at 19:41:09:
Time to check your Mag. If the springs are weak it will start like that. You should hear a distinct snap from the impulse when cranking the engine over.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
