Re: Farmall B start
Posted by JRSutton on June 12, 2013 at 07:14:42 from (75.130.109.233):
In Reply to: Farmall B start posted by Pilot Mike on June 11, 2013 at 19:41:09:
When did this start? any changes made that brought it on? Was it ok, then just started happening? Or is this a new to you tractor?
Having read the other suggestions - I'd add to check the timing.
It should snap right at tdc on the #1 cylinder on the compression stroke.
Might be retarded too far - but advances to an acceptable range once the mag gets spinning fast enough to advance it.
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
