Posted by John T on June 12, 2013 at 12:24:09 from (216.249.76.176):
In Reply to: Battery not charging posted by Jim Paterson on June 12, 2013 at 11:16:16:
If you work through my Troubleshooting Procedure it can help diagnose the cause (genny or VR or wiring or grounds etc) of non charging.
See my Para 5: If dead grounding the gennys FLD post makes her charge but NOT otherwise, the VR isnt well grounded or bad (ON VR syatem) or the light switch is bad or has a bad ground on the cutout relay systems or wires bad from genny up to switch.
PS that system shown is NOT a VR, its a cutout relay system where the light switch regulates charge rate low or high. It MUST have a good frame ground to work!!!!!!!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
